Citirx connectivity is not happening from one serial port
I am facing one weired problem. I m able to connect citris server through one serial port but not able to connect from another serial port.on both the port i have given the same configuration.i am able to telnet to port 1494 and port 80 through that serial port but when i try to connect ICA client it does not happen. I m using frame-relay link.
conf at Int is:
interface Serial1/2
ip address 161.192.104.242 255.255.255.252
ip nat outside
encapsulation frame-relay
no ip mroute-cache
load-interval 30
serial restart_delay 0
no fair-queue
frame-relay map ip 161.192.104.241 89
frame-relay interface-dlci 89
frame-relay lmi-type ansi
interface Serial1/3
ip address 161.192.104.226 255.255.255.252
ip nat outside
no ip mroute-cache
load-interval 30
shutdown
no fair-queue
frame-relay map ip 161.192.104.225 77
frame-relay interface-dlci 77
when i no shut the s1/3 port my both the link goes down. currently i m using only a single port ie s1/2
I have checked layer one connectivity,layer 2 connectivity. I am able to ping from s1/3 and download from the port. only citrix connectivity is not happening.
Kindly help to resolve this problem
thanks
1 REPLY
Bronze
Re: Citirx connectivity is not happening from one serial port
What is the nat doing and where is the citrix server?
90
