Community Member
Class-Based-Qos Mib and 12.1 IOS Not Working
I have configured CBWFQ on a 2610 router running 12.1.19 IOS. However when I do a mib walk I do not get any statistics returned for the Class-Based-QoS mib. When I check on-line it appears that the mib was supported in 12.0 code and later. Why am I not seeing it? I have triple checked the configuration and all appears fine.
1 ACCEPTED SOLUTION
Blue
Re: Class-Based-Qos Mib and 12.1 IOS Not Working
Using CCO MIB Locator Tool (http://www.cisco.com/go/mibs), c2600-ds-mz.121-19.bin does not contain Class-Based-QoS mib. This is a IP/IPX/AT/DEC PLUS image.
Blue
You first may want to check using the CCO MIB Locator Tool (http://www.cisco.com/gom/mibs), whether this particular MIB is present in the IOS image running on this 2610 or not.
Community Member
Says in 12.1.2(E) it is available in the 12.1 series. Does that mean it is not included in mainline release?
Blue
What is the IOS image name that shows up in the 'sh ver' output of this 2610?
Community Member
I'm sorry to ask a basic IOS type of question but I was going under the assumption that something incorporated in early 12.1 code when we are running 12.1(19) would have been incorporated by now. My apologies.
IOS (tm) C2600 Software (C2600-DS-M), Version 12.1(19), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 04-Mar-03 07:53 by kellythw
Image text-base: 0x80008088, data-base: 0x80E14C9C
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
DUMPSMARTS uptime is 23 hours, 26 minutes
System returned to ROM by reload at 14:54:38 EDT Mon Apr 14 2003
System restarted at 14:56:35 EDT Mon Apr 14 2003
System image file is "flash:c2600-ds-mz.121-19.bin"
Blue
152
