class class-default cludge to fix NMS crashing
Guys,
Have a weird question in regards to class class-default.
I have a bug in an NMS system, that if in the class class-default class-map it does not have an amount of bandwidth reserved, it crashes the NMS system. A patch is being applied in two weeks.
Would there be any problems with putting the bandwidth command in the class class-default :
class class-default
bandwidth 1
ie
7300_Metro1>sh policy ken
Policy Map ken
Class class-default
Bandwidth 1 (kbps) Max Threshold 64 (packets)
7300_Metro1>sh policy ken1
Policy Map ken1
Class class-default
7300_Metro1>
The way I understand it is that the bandwidth command is minimum bandwidth only, not maximum bandwidth
and
the bandwdith command can burst over this size in times of congestion and non-congestion.
Could this have any fall out on anything else, say I had priority and bandwidths in other class-maps and then this defaul-class configuration?
the other solution in the time being is to take the bandwidth from the bandwdith and priority commands and set the default-class to the remainder of the bandwdith. Is this approach safer?
Kind regards,
Ken
1 REPLY
Silver
Re: class class-default cludge to fix NMS crashing
After defining the classification parameters, you can use a policy map to apply traffic parameters to these classified flows:
policy-map mypol
class ixia
bandwidth 40000
queue-limit 40
class loopbacks
bandwidth 10000
class class-default
fair-queue
In this case, the flow from the traffic generator is "allocated" a bandwidth of 40 Mbps and a queue depth of 40 packets. The traffic between loopbacks is allocated a bandwidth of 10 Mbps.
http://www.cisco.com/warp/public/121/7200_per-vc-CBWFQ.html
92
