clear a port channle in Catalyst 4006-S2
A Catalyst 4006-S2 with a WS-X4013, 2 WS-X4148-RJ s and a WS-X4306, soft ware is cat4000.6-2-2.bin. The problem is : I miss configured port 4/5-6 to be a channel with command "set port channle 4/5-6 mode on",and in roder to clear this channel, I use the command "set port channle 4/5-6 model off". then the show config command shows that "set port channle 4/5-6 mode off". I can not find the command "clear channle 4/5-6".
How can I clear this channel completely without using the command "clear config"?
Thank you.
1 REPLY
Re: clear a port channle in Catalyst 4006-S2
The default mode is auto. Try "set port channel 4/5-6 mode auto" and then do a "show config 4"
170
