clear ip bgp * soft
Hello all. What does the "soft" in the above command do? I understand that the above command clears the entire bgp routing table, but what effect does the "soft" have?
Thank you for your thoughts.
Silver
Re: clear ip bgp * soft
"soft" reset means clearing the routes recieved from the bgp peer without reseting the session. In other words, soft reset will cause the routers to start processing routing information from scratch and populating bgp table with having to reset the bgp session (TCP port 179).
The "soft" keyword is not required if the 2 routers are running IOS 12.1 and above, because "dynamic refresh" is supported.
Anyway,
here is the documentation:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/iprrp_r/ip2_c1g.htm#1037037
HTH,
Mustafa
Mustafa:
Hello. Yes, I noticed the state change when using the command with and without the "soft" command.
Thanks for your comments,
Robert
hi
the difference is:
the peer relationship is not reset...
which would be a catastrophe in a Real time Env
what is does is ask for updates of the routing info...
from its peer which you specify.,thus mainitaing the relationship and routing info already existing.. as well as getting newest changes from its peers.
hope im right.
if anyone could point out errors..
thankyou
478
