Clearing BGP sessions within VRF's
I've implemented layer3 VPN's using VRF's and address-families.
All is working well except I seem to be missing something when it comes to being able to do clears (soft or hard) on sessions within the vrf.
For example, I can do a 'show ip bgp vpnv4 vrf RED summary' and view the summary of all my BGP routers within that VRF.
Likewise, the form holds true for the following command.
show ip bgp vpnv4 vrf red neighbors 10.1.1.1 advertised-routes
The same form doesn't seem to work however for clearing sessions within that VRF.
ie.
clear ip bgp vpnv4 vrf RED 10.1.1.1 soft out
This form would be in keeping with the 'show' commands, but alas....
Can anybody shed some light ? I'd like to be able to do soft clears on the VRF BGP sessions just like I would in any other non-VRF session.
= K
1 REPLY
Re: Clearing BGP sessions within VRF's
The same VPNv4 session is used to carry all VRF information. You can therefore not clear the session for one single VRF.
Use the following command:
r2#clear ip bgp x.x.x.x vpnv4 unicast ?
in Soft reconfig inbound update
out Soft reconfig outbound update
soft Soft reconfig
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
2469
