Webcast-Catalyst9k
clock not updating on cisco switches
blr1-corp-swa#sh clock
*01:41:50.897 PDT Sat May 22 1993
blr1-corp-swa#
where as updating on the other switch with the same config
blr1-corp-swd#sh clock
.02:51:28.863 PDT Thu Jul 20 2006
blr1-corp-swd#
Re: clock not updating on cisco switches
Have you configured NTP on the routers? Can you give more info about configuration?
If you want to synchronize the time for all your network devices then you should consider using NTP.
By default all devices report it from their local system time.
Narayan
yes I have configured on both the switches, one works & the other doesnot. please see the floowing output
blr1-corp-swc#sh run | inc ntp
ntp clock-period 11259065
ntp server 210.4.192.9
ntp server 210.4.192.13
blr1-corp-swc#sh run | inc cl
clock timezone PST -8
clock summer-time PDT recurring
blr1-corp-swc#sh clock
.04:05:44.312 PDT Thu Jul 20 2006
blr1-corp-swc#
blr1-corp-swa#sh run | inc ntp
ntp peer 210.4.192.9 prefer
ntp server 210.4.192.41
blr1-corp-swa#sh run | inc cl
*02:54:10.135 PDT Sat May 22 1993
blr1-corp-swa#
I also tried changing the NTP peers as follws
but no use
*02:56:54.647 PDT Sat May 22 1993
Are you able to reach the NTP server from the interface which leads to it.
Otherwise you may have add the following command
NTP source
Narayan
yes I am able to reach
Try putting switches to client mode, then they will regularly send request...Here is the command:
ntp client enable
Pls Rate all Posts
there is no such option in my switch.
cbbops08(config)#ntp ?
access-group Control NTP access
authenticate Authenticate time sources
authentication-key Authentication key for trusted time sources
broadcastdelay Estimated round-trip delay
clock-period Length of hardware clock tick
max-associations Set maximum number of associations
peer Configure NTP peer
server Configure NTP server
source Configure interface for source address
trusted-key Key numbers for trusted time sources
cbbops08(config)#
*Feb 28 20:36:14 PST: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/6 (1), with blr1-corp-swf.webex.com FastEthernet0/22 (52).end
cbbops08#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 19-Jun-03 12:37 by antonino
Image text-base: 0x00003000, data-base: 0x0034E2F4
ROM: Bootstrap program is C3500XL boot loader
cbbops08 uptime is 4 hours, 36 minutes
System returned to ROM by reload
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC8.bin"
cisco WS-C3548-XL (PowerPC403) processor (r
*Feb 28 20:36:17 PST: %SYS-5-CONFIG_I: Configured from console by consoleevision 0x01) with 16384K/1024K bytes of memory.
revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Motherboard assembly number: 73-3903-10
Power supply part number: NONE
Power supply serial number: NONE
Model revision number: N0
Motherboard revision number: A0
Model number: WS-C3548-XL-EN
I wonder why when the other switch in the same network with the same running config can work & why not this?
There was a misundersanding...
the command which puts switch to client mode is for 6000 series switches. As I recognized, your devices are 3500 series.
Well... on 3500 series, to put switches to Client mode you only need to configure ntp servers. But they have already configured...
Can you post 'show ntp status' and 'sh ntp association'? Can you check these commands on both switches?
Regards...
So
blr1-corp-swa#sh ntp associations
address ref clock st when poll reach delay offset disp
~210.4.192.9 0.0.0.0 16 - 64 0 0.0 0.00 16000.
~210.4.192.13 0.0.0.0 16 - 64 0 0.0 0.00 16000.
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
blr1-corp-swa#
blr1-corp-swa#
blr1-corp-swa#sh ntp s
blr1-corp-swa#sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 381.4697 Hz, actual freq is 381.4675 Hz, precision is 2**17
reference time is 00000000.00000000 (16:00:00.000 PST Wed Dec 31 1899)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
blr1-corp-swa#
blr1-corp-swd#sh ntp associations
~210.4.192.9 64.68.112.94 3 127d 64 0 413.8 67.57 16000.
~210.4.192.13 64.68.112.94 3 127d 64 0 412.9 62.12 16000.
blr1-corp-swd#
blr1-corp-swd#
blr1-corp-swd#sh ntp st
blr1-corp-swd#sh ntp status
reference time is C7C19A73.6DBB523F (11:39:31.428 PST Tue Mar 14 2006)
clock offset is 62.1180 msec, root delay is 567.93 msec
root dispersion is 111.85 msec, peer dispersion is 23.50 msec
blr1-corp-swd#
Let me know if you need more inputs
Hi again!
I wanna ask one more thing... Have you got any ACLs that restrict Switch A?
no, its not only with this switch, there are few couple of routers & switches where clock is not updating.
619
