Cluster management of Cisco switches
mbowling
Can anyone tell me if it is possible to assign an IP for cluster members in the 10.whatever.whatever range? The cluster commanders throughout our Campus have a valid class C address, but we couldn't use up the entire class C on the members. Will I be able to manage the system with a "10 scope"? Any help would be appreciated.
bowlinm@xavier.edu
bsivasub
Level 4
Level 4
you don't to need assign any ip address for the cluster members..you would be access them from the cluster switch ip address. so assign a class c address for the command switch and you are all set.
Please use this url for reference
http://www.cisco.com/warp/public/473/61.html
