Cluster Management Questions
I have 2 questions about CMS.
1. I have just put in a 2950-12 switch at a remote location that is connected to my office via a 256K frame relay circuit. The CMS is very slow to open the web console i can telnet into the switch with no problem. How do I increase the speed of the web console?
2. Can I connect remote locations in one cluster? The remote locations are all connected by frame relay circuits back to the main office. Each office has it's own subnet.
Thanks in advance
Andy Olsen
  • Other Network Infrastructure Subjects
1 REPLY
Silver
Re: Cluster Management Questions
The switches in a cluster can be in the same location, or they can be distributed across a contiguous Layer 2 network. All communication with cluster switches is through one IP address. Here's the guide to creating and managing clusters.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35xu/scg/kiclust.htm
67
