Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cluster Management Suite or Visual Switch Manager issues
hi all
i m trying to access my cisco 2924XL switche via IE browser,but we r unable to browse CMS/VSM.
I have loaded j2re-1_4_1_02-windows-i586-i.exe to access the same .
its asking me for the uid/passwd and in the taskbar its showing Loadin Java applet but not displaying anything.
i m really curious to acess the VSM/CMS.
plz help me out ...
prem
Re: Cluster Management Suite or Visual Switch Manager issues
you need to define user with priv 15 in your config and also to define http authentication.
Example:
aaa new-model
aaa authentication login default local
username XXXXX privilege 15 password 7 ......
ip http authentication local
Use XXXXX and the password when prompted by CMS.
Some older IOS versions are not compatible with j2re-1_4_1_02 and require j2re-1_3_1 or j2re-1_2_2.
Milan
hi milan
i hve already set privilege 15 thts not the problem for me .its asking for mthe uid and passwd but after tht its getting hanged with blank java screen shwoing nothing on tht.
in taskbar its displaying loading java applet.
prem
which IOS and browser versions are you using?
Have you tried another browser (Netscape, e.g.)?
Milan
Hi Milan
we r using Version 12.0(5)XU and IE 6.0.
i didnt try with another browser .will try the same and get bck.
prem
12.0(5)XU is not compatible with j2re-1_4_1_02. It requires JRE 1.2.2_05.
See Release Notes at http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35xu/1061501.htm#xtocid77402.
Another possibility (recommended) is to upgrade the switch to the latest IOS.
I'm running 12.0(5)WC8 on my switches and it works with j2re-1_4_1_02 with no problem.
Milan
207
