Webcast-Catalyst9k
CMS 3.0 Issue
I have attempted to access my WS-C2950-12 switch using CMS. When ever I attempt to access the web console I keep getting "The page cannot be found". I know that I must be missing something. I need to make this plugin available so that some of the techs that are not very familar with CLI can at least see what is going on.
Todd Hargis
1 REPLY
Re: CMS 3.0 Issue
are you sure there is a correct image installed on your switch?
There should be a /html directory on the flash with the proper.html files.
It's possible that only .bin image file was installed on your switch and you need to replace it with the complete installation including .html files (it should be .tar file downloadeable from the Software Center, follow the Release Notes to install).
If you issue sh flash you should see the image files.
There is also a special CMS plugin necessary to run the latest CMS on 2950s (see http://www.cisco.com/pcgi-bin/tablebuild.pl/CMS-Plug-In-Win-1-0).
Milan
187
