Community Member
combine Flash memory to load an ios
I have the following problem with one of our routers. I have recentlu upgraded a router by adding another flash module (8Mb + 8Mb =16Mb Flash) in order to upgrade IOS.
Now the system has recognised the Flashed and can be listed as flash:1: and flash:2:
I have erased the flash memories using erase flash:1 and flash:2
Now I am trying to copy tftp image to flash.
It get's to a point after defining the name that system ask me to confirm eraseing flash at slot:0: !!! ?? I have no memory at slot 0!! Any ideas why?
How do I define to the system to combine flash memories?
Regards.
Silver
Re: combine Flash memory to load an ios
Have you checked the config file to see it it has the following line:
partition flash 2 8 8
this instrucsts the router to set up two flash partitions of 8Mb each.
If this line exists just do a
no partition flash 2 8 8
then reformat the flash.
hope that helps.
Community Member
yes you are right I used the command
router(config)# partition flash 1
and it fixed my problem.. thanks.
138
