Command help
I am looking for the command to show me the interface that a MAC Address is attached to. I have a Catalyst 6513 running IOS 12.2
I have looked but can't find the one for this IOS. The one I tried are show arp, show mac, show int mac.....none worked.
Mike
1 ACCEPTED SOLUTION
Silver
Re: Command help
Hello Mike,
To display the interface/devie where host 0000.0000.0001 is learnt issue the following commmand:
#show mac-address-table address 0000.0000.0001
Leon
* Please rate useful posts
Silver
Re: Command help
Hello Mike,
Leon
Re: Command help
Thank you very much, that worked....but you knew that :-).....and that was quick!
Enjoy the day,
Mike
Re: Command help
The correct command is: show mac-address-table
This one will give you all mac's the switch knows.
Best is to export the output to an xls or something simlar. You can then search for entries where a specific sequence (adress or port id) is found.
Leo
274
