Command Line Interface
How do I access the command Line interface so I can configure my cisco 2600 router series. I do not seem to know where to do this in my netbook. To which port also can connect the cable to give the router internet.
2 ACCEPTED SOLUTIONS
Bronze
You need to access the console port of the router using a console cable. Your netbook most likely does not have a serial port for this, so you'll need a USB-serial adapter.
Once you have that, you need terminal software. PuTTy is a good lightweight program that you can download for free.
If you want to give the router internet, you need to pick a WAN port. Assuming you don't have an HWIC-ESW in the router, any port will do.
There is a guide here that may be helpful to you:
http://www.internetworkingcareer.com/command-line/how-to-access-the-cisco-cli-from-the-console/
I hope this helps.
Tim
Bronze
Oh nice. Yeah that will do it
Oh nice. Yeah that will do it.
Bronze
I hope this helps.
Tim
Thank you very much. Let me
Thank you very much. Let me give a shot.
Hi Tim,
Hi Tim,
Once I press enter it does not do anything.
Bronze
So when you connected via Serial using Putty it connected but no output?
Can you confirm in Device Manager that the COM port is the one that corresponds to the right serial interface on your laptop?
Also just to confirm, the router is powered on?
If you hit enter a few times do you still get nothing, or do you get weird characters?
Tim
Still nothing. At first it
Still nothing. At first it showed COM1 now nothing. Earlier in it was only a blank dark screen.
Bronze
If you're seeing absolutely nothing it's possible you're using the wrong COM port.
Or you are not plugged into the Console port of the router.
Or you are not using a proper console cable.
Can you attach a screenshot of your device manager with the serial COM ports expanded?
Tim
Okay. I will do that. Give me
Okay. I will do that. Give me a min.
That is my cable, the adapter
That is my cable, the adapter and the screen shot.
Device manager from the
Device manager from the beginning.
Bronze
Everything looks mostly good except for the cable you're using to plug into the console port. That doesn't look like a console cable to me. They're usually light blue in color. They definitely are if they're from Cisco.
Console cables have a different pinout than other cables. They are NOT the same as Ethernet / Crossover / Rollover cables.
Can you confirm that you are using a console cable?
Thank you. I just ordered a
Thank you. I just ordered a light blue usb to console cable from eBay. I will let you know when I get it. Because I really want to get on this pretty soon.
Bronze
Ok. It's USB to console? Can
Ok. It's USB to console? Can you email me the link to the product so I can help you confirm it's the right one?
Tim
http://m.ebay.com/itm
http://m.ebay.com/itm/281736212653?_mwBanner=1
This is the website to the console cable Tim.
Thank you.
Bronze
Thank you for your help and
Thank you for your help and the advice. Do you think after this cable the putty cli will allow me to write by hitting the enter key twice?
Bronze
Yes! Everything else looked
Yes! Everything else looked correct.
Just make sure you install the Windows drivers for this new USB cable and choose the right COM port from Device Manager.
Tim
Hey Tim, another question on
Hey Tim, another question on my Cisco router, what is the function of the space where the network interface card goes? What does a NIC do to the router. Check below
Bronze
That's an empty slot where you can insert a module. For example if you need 4 switch ports, you can plug in a HWIC-4ESW interface card. Or if you need a T1 interface, there's an interface card for that as well. Lots of options based on what you might need.
Tim
Can I put a wireless NIC.
Can I put a wireless NIC. Just curious.
What is the function of the DSU/ CSU port?
Thank you.
Bronze
A CSU/DSU is a digital
A CSU/DSU is a digital-interface device used to connect a data terminal equipment (DTE), such as a router, to a digital circuit, such as a Digital Signal 1 (T1) line.
The above is from Wikipedia.
You can see which HWIC cards your router supports on this page:
http://www.cisco.com/c/en/us/support/docs/routers/1600-series-routers/15363-wics.html
Doesn't look like any Cellular / WLAN cards are on the list because the 2600 model is older. The 2800 series for sure can.
Tim
Khrushchev Tim, I am trying
  • Khrushchev Tim, I am trying to change the password for this router since it seems it has one for the previous user but it went let me.  Please advice.
Bronze
Hi there,
Hi there,
You need to password reset it... you can use this guide here which explains how: http://www.internetworkingcareer.com/blog/perform-password-recovery-cisco-routers/
Tim
After I do this, what is
After I do this, what is going to be the username?
Bronze
You have asked many questions under this one forum topic which is no longer relevant to the original question. This is not going to be helpful to anyone else at this rate.
If you want to continue this discussion, you can create a topic here: http://www.internetworkingcareer.com/forums/networking-discussion/ and i will be happy to respond to you directly.
Otherwise, please create a new topic in Cisco forums and someone will pick it up.
Tim
Thank you. I will do that.
Can I put a wireless NIC there? Just curious. Thank you. And which is the better one?
I got the device manager
I got the device manager thing.
185
