Community Member
Compatibility between 3725 and 3640 Cisco Routers
I would like to remove the PRI Modules for the below Configuration, but not sure if this can be plugged to CISCO model 3640 ? Is it compatible? Please advise
thks!
Cisco IOS Software, 3700 Software (C3725-ADVIPSERVICESK9-M), Version 12.3(8)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Tue 20-Jul-04 20:30 by eaarmas
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
W-R2 uptime is 30 weeks, 4 days, 1 hour, 4 minutes
System restarted at 12:55:31 SIN Fri Jul 8 2005
System image file is "flash:c3725-advipservicesk9-mz.123-8.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3725 (R7000) processor (revision 0.1) with 250880K/11264K bytes of memory.
Processor board ID JPE083611Q0
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
2 FastEthernet interfaces
62 Serial interfaces
2 Serial(sync/async) interfaces
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
1 REPLY
Silver
Re: Compatibility between 3725 and 3640 Cisco Routers
Could you post the output from "sh diag" for the 3725 in order to see the PRI card model ?
285
