Compatibility Issues
Hi Guys,
currently i have windows 8.1 pro loaded on my laptop. since upgrading from win 7 i am unable to console into any POE switch with
IOS 15 loaded. is there any current issues regrading compatibility. Or is this maybe an issue with SecureCRT?
Hi, Have you tried with other
Have you tried with other tools?
Is it working ?
Gurudath K S
Hi Guru, I have tried with
Hi Guru,
I have tried with putty and that seems to work. Also its not just me. A colleague of mine
has the exact same problem.
Did the COM port of your
Did the COM port of your console cable just change? I've seen that happen with system upgrades.
Hi Kevin, Nope nothing has
Hi Kevin,
Nope nothing has changed. And when it did i did make shure that the setting were correct.
I can see the switch boot up. I can see it load the ios. But it does not go further than that. I cant actually configure the switch
Hi, If you want to use
If you want to use SecureCRT then you will require Serial cable.
You can also use putty. its easy
Hi Jerry,I am using a serial
Hi Jerry,
I am using a serial to usb cable that connects to a Cisco console cable. my COM port settings are correct as i can console into non POE 2960 switches. However i am unable to console into a POE switch. it gets as far as POST. I can see the switch boot.
74
