compatibility issues
i have ML 450 hp server running trend micro and is used as antivirus server but i have enough space on the server left so can i use the server for cisco works LMS 2.5 installation , i hope the services of the anivirus server are not effected.
1 REPLY
Silver
Re: compatibility issues
It depends on how many network assets you want to manage throug LMS.
It is advised to use a dedicated server for LMS, however if you run a small networks that has less than 100 devices (router, switches et cetera) it wouldn't be a problem.
Note that syslog, config deltas and software images can eat up a lot of your diskspace.
Leon
* Please rate useful posts.
Leon
98
