Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Compatibility problems between Catalyst 2924XL and Digi FAST TWIST Model MIL-180 converter of Milan
<p>When you tune router buffers, does the router require a reload for the changes to take effect?
1 REPLY
Anonymous
N/A
Re: Compatibility problems between Catalyst 2924XL and Digi FAST
There have been reports of some issues with the Digi converter and XL switches.
You need to configure the port speed/duplex manually on both sides of the connection.
This may resolve the issue.
307
