Compatibility problems between Catalyst 2924XL and Digi FAST TWIST Model MIL-180 converter of Milan
<p>When you tune router buffers, does the router require a reload for the changes to take effect?
1 REPLY
Anonymous
N/A
Re: Compatibility problems between Catalyst 2924XL and Digi FAST
There have been reports of some issues with the Digi converter and XL switches.
You need to configure the port speed/duplex manually on both sides of the connection.
This may resolve the issue.
115
