Community Member
Compression Engine Port adapter
I have a 3640.
With the she "show diag" I have the following indications :
Slot 2:
1.5M DRAM Compression Engine Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Do you know what is the reference of this card ?
Thank You.
Michel.
1 REPLY
Silver
Re: Compression Engine Port adapter
Michel,
The compression network module (Cisco product number NM-COMPR) does not provide network interfaces of its own, but instead compresses and
decompresses data passing through interfaces on other network modules or WAN interface cards in the router.
Here is the URL for this Compression PA.
http://www.cisco.com/en/US/partner/products/hw/modules/ps2797/products_module_installation_guide_chapter09186a008007c8e5.html
Hope this helps you,
Don
84
