compression on a dialer interface.
I want to use software compression on ISDN dial backup lines. I currently use compression for analog backup via an ISDN pri and MICA modems with no problems. When I try to invoke compression on ISDN calls it does not negotiate compression. Am I missing something in the config? Below are the conifg parameters and debug output from the peripheral and the catcher router..
Peripheral config:(2650/12.2(7a))
interface BRI1/0
no ip address
encapsulation ppp
no ip mroute-cache
dialer rotary-group 0
isdn switch-type basic-ni
isdn spid1 015120867000
isdn spid2 015120885000
compress stac
no cdp enable
!interface BRI1/1
no ip address
encapsulation ppp
no ip mroute-cache
isdn spid1 015121523000
isdn spid2 015129507000
compress stac
no cdp enable
interface Dialer0
ip address xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy
encapsulation ppp
ip ospf network point-to-multipoint
ip ospf hello-interval 10
no ip mroute-cache
dialer in-band
dialer string 18888772210
dialer load-threshold 1 outbound
dialer-group 1
compress stac
no cdp enable
ppp authentication chap
ppp chap password 7 121E0816401F000B26
ppp multilink
Peripheral debug (ppp negotiation)
GGRTR(config-if)#int dialer0
GGRTR(config-if)#no shut
GGRTR(config-if)#
*Mar 9 16:29:58.181: %LINK-3-UPDOWN: Interface BRI1/1:1, changed state to up
*Mar 9 16:29:58.185: BR1/1:1 PPP: Treating connection as a callout
*Mar 9 16:29:58.185: BR1/1:1 PPP: Phase is ESTABLISHING, Active Open [0 sess, 2 load]
*Mar 9 16:29:58.185: BR1/1:1 LCP: O CONFREQ [Closed] id 17 len 27
*Mar 9 16:29:58.185: BR1/1:1 LCP: AuthProto CHAP (0x0305C22305)
*Mar 9 16:29:58.185: BR1/1:1 LCP: MagicNumber 0x35BA8724 (0x050635BA8724)
*Mar 9 16:29:58.185: BR1/1:1 LCP: MRRU 1524 (0x110405F4)
*Mar 9 16:29:58.189: BR1/1:1 LCP: EndpointDisc 1 GGRTR (0x1308014747525452)
*Mar 9 16:29:58.213: BR1/1:1 LCP: I CONFREQ [REQsent] id 36 len 29
*Mar 9 16:29:58.213: BR1/1:1 LCP: AuthProto CHAP (0x0305C22305)
*Mar 9 16:29:58.213: BR1/1:1 LCP: MagicNumber 0x79FDEBB5 (0x050679FDEBB5)
*Mar 9 16:29:58.213: BR1/1:1 LCP: MRRU 1524 (0x110405F4)
*Mar 9 16:29:58.213: BR1/1:1 LCP: EndpointDisc 1 Catcher (0x130A0143617463686572)
*Mar 9 16:29:58.213: BR1/1:1 LCP: O
GGRTR(config-i CONFACK [REQsent] id 36 len 29
*Mar 9 16:29:58.217: BR1/1:1 LCP: I CONFACK [ACKsent] id 17 len 27
*Mar 9 16:29:58.217: BR1/1:1 LCP: AuthProto CHAP (0x0305C22305)
*Mar 9 16:29:58.217: BR1/1:1 LCP: MagicNumber 0x35BA8724 (0x050635BA8724)
*Mar 9 16:29:58.217: BR1/1:1 LCP: MRRU 1524 (0x110405F4)
*Mar 9 16:29:58.217: BR1/1:1 LCP: EndpointDisc 1 GGRTR (0x1308014747525452)
*Mar 9 16:29:58.217: BR1/1:1 LCP: State is Open
*Mar 9 16:29:58.221: BR1/1:1 PPP: Phase is AUTHENTICATING, by both [0 sess, 1 load]
*Mar 9 16:29:58.221: BR1/1:1 CHAP: O CHALLENGE id 12 len 26 from "XXX"
*Mar 9 16:29:58.237: BR1/1:1 CHAP: I CHALLENGE id 16 len 28 from "YYY"
*Mar 9 16:29:58.237: BR1/1:1 CHAP: O RESPONSE id 16 len 26 from "XXX"
*Mar 9 16:29:58.261: BR1/1:1 CHAP: I SUCCESS id 16 len 4
*Mar 9 16:29:58.265: BR1/1:1 CHAP: I RESPONSE id 12 len 28 from "YYY"
*Mar 9 16:29:58.265: BR1/1:1 CHAP: O SUCCESS id 12 len 4
*Mar 9 16:29:58.265: BR1/1:1 PPP: Phase is VIRTUALIZED [0 sess, 1 load]
*Mar 9 16:29:58.269: Vi1 PPP: Phase is DOWN, Setup [0 sess, 1 load]
*Mar 9 16:29:58.269: Vi1 PPP: No remote authentication for call-out
*Mar 9 16:29:58.269: Vi1 PPP: Phase is ESTABLISHING [0 sess, 1 load]
*Mar 9 16:29:58.269: Vi1 CCP: Compression already closed
*Mar 9 16:29:58.269: Vi1 CCP: Re-Syncing history using legacy method
*Mar 9 16:29:58.277: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 9 16:29:58.281: Vi1 PPP: Treating connection as a callout
*Mar 9 16:29:58.281: Vi1 LCP: O CONFREQ [Closed] id 1 len 27
*Mar 9 16:29:58.281: Vi1 LCP: AuthProto CHAP (0x0305C22305)
*Mar 9 16:29:58.281: Vi1 LCP: MagicNumber 0x35BA8787 (0x050635BA8787)
*Mar 9 16:29:58.281: Vi1 LCP: MRRU 1524 (0x110405F4)
*Mar 9 16:29:58.281: Vi1 LCP: EndpointDisc 1 GGRTR (0x1308014747525452)
*Mar 9 16:29:58.285: Vi1 PPP: Phase is UP [0 sess, 1 load]
*Mar 9 16:29:58.289: Vi1 IPCP: O CONFREQ [Closed] id 1 len 10
*Mar 9 16:29:58.289: Vi1 IPCP: Address 11.229.111.41 (0x03060BE56F29)
*Mar 9 16:29:58.289: Vi1 CCP: Compression already closed
*Mar 9 16:29:58.289: Vi1 CCP: O CONFREQ [Closed] id 1 len 10
*Mar 9 16:29:58.289: Vi1 CCP: LZSDCP history 1 check mode SEQ process UNCOMPRESSSED (0x170600010201)
*Mar 9 16:29:58.289: Vi1 MLP: Added first link BR1/1:1 to bundle Catcher
*Mar 9 16:29:58.297: Vi1 IPCP: I CONFREQ [REQsent] id 1 len 10
*Mar 9 16:29:58.297: Vi1 IPCP: Address 11.229.136.245 (0x03060BE588F5)
*Mar 9 16:29:58.297: Vi1 IPCP: O CONFACK [REQsent] id 1 len 10
*Mar 9 16:29:58.297: Vi1 CCP: I CONFREQ [REQsent] id 1 len 10
*Mar 9 16:29:58.297: Vi1 CCP: LZSDCP history 1 check mode SEQ process UNCOMPRESSSED (0x170600010201)
*Mar 9 16:29:58.297: Vi1 CCP: O CONFACK [REQsent] id 1 len 10
*Mar 9 16:29:58.301: Vi1 CCP: LZSDCP history 1 check mode SEQ process UNCOMPRESSSED (0x170600010201)
*Mar 9 16:29:58.305: Vi1 IPCP: I CONFACK [ACKsent] id 1 len 10
*Mar 9 16:29:58.305: Vi1 IPCP: Address 11.229.111.41 (0x03060BE56F29)
*Mar 9 16:29:58.309: Vi1 IPCP: State is Open
*Mar 9 16:29:58.309: Vi1 CCP: I CONFACK [ACKsent] id 1 len 10
*Mar 9 16:29:58.309: Vi1 CCP: LZSDCP history 1 check mode SEQ process UNCOMPRESSSED (0x170600010201)
*Mar 9 16:29:58.309: Vi1 CCP: State is Open
*Mar 9 16:29:58.313: Vi1 CCP: ppp_hwcomp_open: no h/w
*Mar 9 16:29:58.313: Di0 IPCP: Install route to xxx.xxx.xxx.xxx
*Mar 9 16:29:58.618: %LINK-3-UPDOWN: Interface Dialer0, changed state to up
*Mar 9 16:29:58.622: Di0 LCP: Not allowed on a Rotary Group
*Mar 9 16:29:59.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/1:1, changed state to up
*Mar 9 16:29:59.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Mar 9 16:30:01.715: %OSPF-5-ADJCHG: Process 1, Nbr xxx.xxx.xxx.xxx on Dialer0 from LOADING to FULL, Loading Done
*Mar 9 16:30:02.336: %LINK-3-UPDOWN: Interface BRI1/1:2, changed state to up
******After an FTP of a text file********
GGRTR#sho compress
Dialer0
Software compression enabled
uncompressed bytes xmt/rcv 0/0
1 min avg ratio xmt/rcv 0.000/0.000
5 min avg ratio xmt/rcv 0.000/0.000
10 min avg ratio xmt/rcv 0.000/0.000
no bufs xmt 0 no bufs rcv 0
resyncs 0
Additional Stacker Stats:
Transmit bytes: Uncompressed = 0 Compressed = 0
Received bytes: Compressed = 0 Uncompressed = 0
Central catcher router config:
interface Serial2/0:23
no ip address
encapsulation ppp
ip mroute-cache
isdn switch-type primary-ni
isdn incoming-voice modem
compress stac
no cdp enable
interface Group-Async1
no ip address
no ip mroute-cache
dialer in-band
async default routing
async mode dedicated
no fair-queue
compress stac
group-range 97 120
interface Dialer0
ip address 11.229.136.245 255.0.0.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer-group 1
no peer default ip address
compress stac
no cdp enable
ppp chap password 7 'deleted'
ppp multilink
  • Other Network Infrastructure Subjects
Re: compression on a dialer interface.
From the debug, the compression did get negotiated fine..as we have CCP state is open
There are many issue in compression related areas reported..
Some very well knowns are
CSCdx65221 which is reported for "Compression statictics not gathered on virtual access interface" while data gets compressed fine.
CSC09965 : Software compression reported 0 counts on dialer rotary-groups
So you can turn on "debug compression" and try to do ping or ftp and see the data gets compressed or not..Follow the debug and load the fixed version of the ios near latest..
I will also suggest to look for upgrading IOS .
Please have a look at the release note
I made a setup with a AS5800 running 12.2(7)
The test has been sucessfull for MPPC and ip tcp header-compression
Please see below my interesting outputs and comments which will help you.
I will put the case in close-pending.
regards
Jean-Michel
Cisco Systems - TAC
Jean-Michel Veyne
Phone : +32 2 704 5162
ccie# 7025
Two test have been made
1) compress mppc
2) ip tcp header-compression
1) compress mppc
interface Serial1/0/0:15
no ip address
encapsulation ppp
dialer rotary-group 1
isdn switch-type primary-net5
compress mppc
interface Dialer1
ip unnumbered FastEthernet0/0/0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer-group 1
peer default ip address pool default
compress mppc
ppp authentication chap pap callin
end
dynamite#sh debug
PPP:
PPP protocol negotiation debugging is on
ISDN:
ISDN Q931 packets debugging is on
ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
1 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
DSL 32 --> 55
dynamite#
===> In the debug below, if you see : CCP: State is Open
it means that compress mppc is active
dynamite#
*Mar 20 14:41:20.899: ISDN Se1/0/0:15: RX <- SETUP pd = 8 callref = 0x002B
*Mar 20 14:41:20.899: Bearer Capability i = 0x8890
*Mar 20 14:41:20.899: Channel ID i = 0xA98381
*Mar 20 14:41:20.903: Called Party Number i = 0x81, '3', Plan:ISDN, Type:Unknown
*Mar 20 14:41:20.903: Se1/0/0:0 PPP: Treating connection as a callin
*Mar 20 14:41:20.903: Se1/0/0:0 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
*Mar 20 14:41:20.903: Se1/0/0:0 LCP: State is Listen
*Mar 20 14:41:20.903: ISDN Se1/0/0:15: TX -> CALL_PROC pd = 8 callref = 0x802B
*Mar 20 14:41:20.903: Channel ID i = 0xA98381
*Mar 20 14:41:20.903: ISDN Se1/0/0:15: TX -> CONNECT pd = 8 callref = 0x802B
*Mar 20 14:41:20.919: Se1/0/0:0 LCP: I CONFREQ [Listen] id 33 len 10
*Mar 20 14:41:20.919: Se1/0/0:0 LCP: MagicNumber 0x1545BF93 (0x05061545BF93)
*Mar 20 14:41:20.919: Se1/0/0:0 LCP: O CONFREQ [Listen] id 16 len 15
*Mar 20 14:41:20.919: Se1/0/0:0 LCP: AuthProto CHAP (0x0305C22305)
*Mar 20 14:41:20.919: Se1/0/0:0 LCP: MagicNumber 0xD020DD82 (0x0506D020DD82)
*Mar 20 14:41:20.919: Se1/0/0:0 LCP: O CONFACK [Listen] id 33 len 10
*Mar 20 14:41:20.919: ISDN Se1/0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x002B
*Mar 20 14:41:20.919: ISDN Se1/0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0xA, bchan 0, dsl 0
*Mar 20 14:41:20.927: Se1/0/0:0 LCP: I CONFACK [ACKsent] id 16 len 15
*Mar 20 14:41:20.927: Se1/0/0:0 LCP: AuthProto CHAP (0x0305C22305)
*Mar 20 14:41:20.927: Se1/0/0:0 LCP: MagicNumber 0xD020DD82 (0x0506D020DD82)
*Mar 20 14:41:20.927: Se1/0/0:0 LCP: State is Open
*Mar 20 14:41:20.927: Se1/0/0:0 PPP: Phase is AUTHENTICATING, by this end [0 sess, 0 load]
*Mar 20 14:41:20.927: Se1/0/0:0 CHAP: O CHALLENGE id 10 len 29 from "dynamite"
*Mar 20 14:41:20.943: Se1/0/0:0 CHAP: I RESPONSE id 10 len 26 from "cisco"
*Mar 20 14:41:20.943: Se1/0/0:0 CHAP: O SUCCESS id 10 len 4
*Mar 20 14:41:20.943: Se1/0/0:0 PPP: Phase is UP [0 sess, 0 load]
*Mar 20 14:41:20.943: Se1/0/0:0 IPCP: O CONFREQ [Closed] id 4 len 10
*Mar 20 14:41:20.943: Se1/0/0:0 IPCP: Address 10.48.74.125 (0x03060A304A7D)
*Mar 20 14:41:20.943: Se1/0/0:0 CCP: Compression already closed
*Mar 20 14:41:20.943: Se1/0/0:0 CCP: O CONFREQ [Closed] id 4 len 10
*Mar 20 14:41:20.943: Se1/0/0:0 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
*Mar 20 14:41:20.943: Se1/0/0:0 CDPCP: O CONFREQ [Closed] id 4 len 4
*Mar 20 14:41:20.951: Se1/0/0:0 IPCP: I CONFREQ [REQsent] id 17 len 16
*Mar 20 14:41:20.951: Se1/0/0:0 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
*Mar 20 14:41:20.951: Se1/0/0:0 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 20 14:41:20.951: Se1/0/0:0 IPCP: Pool returned 192.168.100.1
*Mar 20 14:41:20.951: Se1/0/0:0 IPCP: O CONFREJ [REQsent] id 17 len 10
*Mar 20 14:41:20.951: Se1/0/0:0 CCP: I CONFREQ [REQsent] id 4 len 10
*Mar 20 14:41:20.951: Se1/0/0:0 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
*Mar 20 14:41:20.951: Se1/0/0:0 CCP: O CONFACK [REQsent] id 4 len 10
*Mar 20 14:41:20.955: Se1/0/0:0 CDPCP: I CONFREQ [REQsent] id 14 len 4
*Mar 20 14:41:20.955: Se1/0/0:0 CDPCP: O CONFACK [REQsent] id 14 len 4
*Mar 20 14:41:20.955: Se1/0/0:0 IPCP: I CONFACK [REQsent] id 4 len 10
*Mar 20 14:41:20.955: Se1/0/0:0 IPCP: Address 10.48.74.125 (0x03060A304A7D)
*Mar 20 14:41:20.959: Se1/0/0:0 CCP: I CONFACK [ACKsent] id 4 len 10
*Mar 20 14:41:20.959: Se1/0/0:0 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
*Mar 20 14:41:20.959: Se1/0/0:0 CCP: State is Open
*Mar 20 14:41:20.959: Se1/0/0:0 CCP: ppp_hwcomp_open: no h/w
*Mar 20 14:41:20.959: Se1/0/0:0 CDPCP: I CONFACK [ACKsent] id 4 len 4
*Mar 20 14:41:20.959: Se1/0/0:0 CDPCP: State is Open
*Mar 20 14:41:20.963: Se1/0/0:0 IPCP: I CONFREQ [ACKrcvd] id 18 len 10
*Mar 20 14:41:20.963: Se1/0/0:0 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 20 14:41:20.963: Se1/0/0:0 IPCP: O CONFNAK [ACKrcvd] id 18 len 10
*Mar 20 14:41:20.963: Se1/0/0:0 IPCP: Address 192.168.100.1 (0x0306C0A86401)
*Mar 20 14:41:20.971: Se1/0/0:0 IPCP: I CONFREQ [ACKrcvd] id 19 len 10
*Mar 20 14:41:20.971: Se1/0/0:0 IPCP: Address 192.168.100.1 (0x0306C0A86401)
*Mar 20 14:41:20.971: Se1/0/0:0 IPCP: O CONFACK [ACKrcvd] id 19 len 10
*Mar 20 14:41:20.971: Se1/0/0:0 IPCP: State is Open
*Mar 20 14:41:20.971: Di1 IPCP: Install route to 192.168.100.1
*Mar 20 14:41:20.975: %IP-4-DUPADDR: Duplicate address 10.48.74.125 on FastEthernet0/0/0, sourced by 0010.7be6.4498
dynamite#
======> CCP is open : see line 11
dynamite#sh int Se1/0/0:0
Serial1/0/0:0 is up, line protocol is up
Hardware is DS-E1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation PPP, crc 16, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Time to interface disconnect: idle 00:01:47
LCP Open
Open: IPCP, CCP, CDPCP <================ CCP is opened
Last input 00:00:12, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:13:05
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
141 packets input, 3756 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
129 packets output, 3173 bytes, 0 underruns
5 carrier transitions no alarm present
Timeslot(s) Used:1, subrate: 64Kb/s, transmit delay is 0 flags
dynamite#
==========> sh compress
dynamite#sh compress | b Serial1/0/0:0
Serial1/0/0:0
uncompressed bytes xmt/rcv 15440/16658
1 min avg ratio xmt/rcv 5.179/5.814
5 min avg ratio xmt/rcv 5.179/5.814
10 min avg ratio xmt/rcv 5.179/5.814
resyncs 0
---> after a ping from the client to the AS5800, we can see the counters increasing
Serial1/0/0:0
uncompressed bytes xmt/rcv 16242/17168
1 min avg ratio xmt/rcv 5.064/5.686
5 min avg ratio xmt/rcv 5.064/5.686
10 min avg ratio xmt/rcv 5.064/5.686
resyncs 0
==========> other way to check : by monitoring the numbers of output packets
dynamite#clear counters
Clear "show interface" counters on all interfaces [confirm]
---> first i check the ip address of the remote
dynamite#sh caller ip
Line User IP Address Local Number Remote Number <->
Se1/0/0:0 cisco 192.168.100.1 3 in
-----> then I ping the remote : 1 ping of 1000 bytes
dynamite#ping
Protocol [ip]:
Target IP address: 192.168.100.1
Repeat count [5]: 1
Datagram size [100]: 1000
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 1, 1000-byte ICMP Echos to 192.168.100.1, timeout is 2 seconds:
Success rate is 100 percent (1/1), round-trip min/avg/max = 20/20/20 ms
----> then i check the counters : 6 packets output, 117 bytes
117 is less than 1000 bytes meaning that compression is active
Hardware is DS-E1
Time to interface disconnect: idle 00:01:54
LCP Open
Last input 00:00:05, output 00:00:05, output hang never
Last clearing of "show interface" counters 00:00:21
5 packets input, 107 bytes, 0 no buffer
6 packets output, 117 bytes, 0 underruns
0 carrier transitions no alarm present
with debug ppp packet
2) with ip tcp header-compression
no ip address
encapsulation ppp
ip tcp header-compression passive
interface Dialer1
encapsulation ppp
dialer in-band
dialer-group 1
end
dynamite#
====> In the debug below, you will not see amy compression negotiation
It makes sense since "ip tcp header compression" is not part of PPP
dynamite#
dynamite#
dynamite#
dynamite#
*Mar 20 15:12:50.531: ISDN Se1/0/0:15: RX <- SETUP pd = 8 callref = 0x0031
*Mar 20 15:12:50.531: Bearer Capability i = 0x8890
*Mar 20 15:12:50.531: Channel ID i = 0xA98381
*Mar 20 15:12:50.531: Called Party Number i = 0x81, '3', Plan:ISDN, Type:Unknown
*Mar 20 15:12:50.535: Se1/0/0:0 PPP: Treating connection as a callin
*Mar 20 15:12:50.535: Se1/0/0:0 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
*Mar 20 15:12:50.535: Se1/0/0:0 LCP: State is Listen
*Mar 20 15:12:50.535: ISDN Se1/0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8031
*Mar 20 15:12:50.535: Channel ID i = 0xA98381
*Mar 20 15:12:50.535: ISDN Se1/0/0:15: TX -> CONNECT pd = 8 callref = 0x8031
*Mar 20 15:12:50.559: Se1/0/0:0 LCP: I CONFREQ [Listen] id 39 len 10
*Mar 20 15:12:50.559: Se1/0/0:0 LCP: MagicNumber 0x15629511 (0x050615629511)
*Mar 20 15:12:50.559: Se1/0/0:0 LCP: O CONFREQ [Listen] id 26 len 15
*Mar 20 15:12:50.559: Se1/0/0:0 LCP: AuthProto CHAP (0x0305C22305)
*Mar 20 15:12:50.559: Se1/0/0:0 LCP: MagicNumber 0xD03DB2F5 (0x0506D03DB2F5)
*Mar 20 15:12:50.559: Se1/0/0:0 LCP: O CONFACK [Listen] id 39 len 10
*Mar 20 15:12:50.559: ISDN Se1/0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0031
*Mar 20 15:12:50.559: ISDN Se1/0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x10, bchan 0, dsl 0
*Mar 20 15:12:50.571: Se1/0/0:0 LCP: I CONFACK [ACKsent] id 26 len 15
*Mar 20 15:12:50.571: Se1/0/0:0 LCP: AuthProto CHAP (0x0305C22305)
*Mar 20 15:12:50.571: Se1/0/0:0 LCP: MagicNumber 0xD03DB2F5 (0x0506D03DB2F5)
*Mar 20 15:12:50.571: Se1/0/0:0 LCP: State is Open
*Mar 20 15:12:50.571: Se1/0/0:0 PPP: Phase is AUTHENTICATING, by this end [0 sess, 0 load]
*Mar 20 15:12:50.571: Se1/0/0:0 CHAP: O CHALLENGE id 16 len 29 from "dynamite"
*Mar 20 15:12:50.583: Se1/0/0:0 CHAP: I RESPONSE id 16 len 26 from "cisco"
*Mar 20 15:12:50.583: Se1/0/0:0 CHAP: O SUCCESS id 16 len 4
*Mar 20 15:12:50.583: Se1/0/0:0 PPP: Phase is UP [0 sess, 0 load]
*Mar 20 15:12:50.583: Se1/0/0:0 IPCP: O CONFREQ [Closed] id 10 len 16
*Mar 20 15:12:50.583: Se1/0/0:0 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
*Mar 20 15:12:50.583: Se1/0/0:0 IPCP: Address 10.48.74.125 (0x03060A304A7D)
*Mar 20 15:12:50.583: Se1/0/0:0 CDPCP: O CONFREQ [Closed] id 10 len 4
*Mar 20 15:12:50.591: Se1/0/0:0 IPCP: I CONFREQ [REQsent] id 32 len 16
*Mar 20 15:12:50.591: Se1/0/0:0 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
*Mar 20 15:12:50.591: Se1/0/0:0 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 20 15:12:50.591: Se1/0/0:0 IPCP: Pool returned 192.168.100.1
*Mar 20 15:12:50.591: Se1/0/0:0 IPCP: O CONFNAK [REQsent] id 32 len 10
*Mar 20 15:12:50.591: Se1/0/0:0 IPCP: Address 192.168.100.1 (0x0306C0A86401)
*Mar 20 15:12:50.595: Se1/0/0:0 CCP: I CONFREQ [Not negotiated] id 10 len 10
*Mar 20 15:12:50.595: Se1/0/0:0 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
*Mar 20 15:12:50.595: Se1/0/0:0 LCP: O PROTREJ [Open] id 27 len 16 protocol CCP (0x80FD010A000A120600000001)
*Mar 20 15:12:50.595: Se1/0/0:0 CDPCP: I CONFREQ [REQsent] id 20 len 4
*Mar 20 15:12:50.595: Se1/0/0:0 CDPCP: O CONFACK [REQsent] id 20 len 4
*Mar 20 15:12:50.599: Se1/0/0:0 IPCP: I CONFACK [REQsent] id 10 len 16
*Mar 20 15:12:50.599: Se1/0/0:0 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
*Mar 20 15:12:50.599: Se1/0/0:0 IPCP: Address 10.48.74.125 (0x03060A304A7D)
*Mar 20 15:12:50.599: Se1/0/0:0 CDPCP: I CONFACK [ACKsent] id 10 len 4
*Mar 20 15:12:50.599: Se1/0/0:0 CDPCP: State is Open
*Mar 20 15:12:50.603: Se1/0/0:0 IPCP: I CONFREQ [ACKrcvd] id 33 len 16
*Mar 20 15:12:50.603: Se1/0/0:0 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
*Mar 20 15:12:50.603: Se1/0/0:0 IPCP: Address 192.168.100.1 (0x0306C0A86401)
*Mar 20 15:12:50.603: Se1/0/0:0 IPCP: O CONFACK [ACKrcvd] id 33 len 16
*Mar 20 15:12:50.603: Se1/0/0:0 IPCP: State is Open
*Mar 20 15:12:50.607: Di1 IPCP: Install route to 192.168.100.1
*Mar 20 15:12:50.611: %IP-4-DUPADDR: Duplicate address 10.48.74.125 on FastEthernet0/0/0, sourced by 0010.7be6.4498
dynamite#
dynamite#sh interfaces Se1/0/0:0
Hardware is DS-E1
Time to interface disconnect: idle 00:01:43
LCP Open
Open: IPCP, CDPCP
Last input 00:00:16, output 00:00:04, output hang never
Last clearing of "show interface" counters 00:32:00
Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
532 packets input, 31169 bytes, 0 no buffer
1 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored, 0 abort
495 packets output, 29275 bytes, 0 underruns
1 output errors, 0 collisions, 0 interface resets
18 carrier transitions no alarm present
dynamite#
==> you can check with
The counters are set to 0 because i ididn't generate any tcp traffic
dynamite# sh ip tcp header-compression | b Interface Serial1/0/0:0:
Interface Serial1/0/0:0: (passive, compression on)
Rcvd: 0 total, 0 compressed, 0 errors
0 dropped, 0 buffer copies, 0 buffer failures
Sent: 0 total, 0 compressed,
0 bytes saved, 0 bytes sent
Connect: 16 rx slots, 16 tx slots,
0 long searches, 0 misses 0 collisions, 0 negative cache hits
===> you can check with the counters as previously
===> you can check with debug ppp packets as well
376
