Webcast-Catalyst9k
Config C2600 Router to bridge Ethernet and Tokenring on same subnet - how?
Hi - can anyone advise as to the best configuration to apply to a C2600 router in order to bridge layer 2 traffic between ethernet and token ring on the same subnet?
cheers
Erik
Bronze
Re: Config C2600 Router to bridge Ethernet and Tokenring on same
Hi Erik
You need source-route translational bridging (SR/TLB).
Check the link below and search for SRB, it is the config guide:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/ibm_c/bcprt1/bcdsrb.htm
Hope that helps.
Roger
Thanks Roger
Erik
141
