Configuration help with 2610 router and new NM-1E module.
I have a CISCO 2610 with WIC T1 and the 1 Fast Ethernet port that is part of the 2610 router and I have added 32 MB of RAM for a total of 64 MB RAM. I have now added a new NM-1E module. Here is a
show conf: (see problem/question below configuration)
Using 870 out of 29688 bytes
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Router
no logging console
enable password **********
ip subnet-zero
ip domain-name integraonline.com
ip name-server 206.163.82.4
interface FastEthernet0/0
ip address 198.x.x.x x.255.255.240
no ip directed-broadcast
duplex auto
speed auto
interface Serial0/0
ip address 198.x.x.x x.255.255.252
encapsulation ppp
no ip mroute-cache
no fair-queue
interface Ethernet1/0
ip address 192.168.100.251 255.255.255.0
ip classless
ip oute 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
access-list 7 permit 192.168.100.0 0.0.0.254
route-map router permit 10
line con 0
exec-timeout 0 0
transport input none
line aux 0
line vty 0 4
password **********
login
end
Problem: FastEthernet 0/0 has been working good for 2 years. The Ethernet 1/0 (which I just added) can NOT see any WAN ip addresses. I can ping any of my assigned ip addresses 198.107.30.17 thru 198.107.30.30 and I can see Serial 0/0 at 198.107.20.234 but I can NOT see my providers gateway 198.107.20.233 from my LAN 192.168.100.XXX or anyother WAN ip addresses. I am pinging from a computer with an ip address of 192.168.100.248 Any help with my configuration to get it working or to speed things up would be greatly appreciated! Thank you for your time!!
If I were to update the IOS what version should I update too?
1 REPLY
VIP Purple
Re: Configuration help with 2610 router and new NM-1E module.
I can ping your addresses 198.107.30.17 and 198.107.20.234 from the Internet, but I cannot ping 192.168.100.248. That is because the 192.168 range is private space, which means those addresses can never ping or reach any public IP addresses like those assigned from your provider, from the 198.107 range. You need to apply Network Address Translation to your configuration, here is what your configuration should look like (the additions have start with a -->):
version 12.0
hostname Router
no logging console
ip subnet-zero
ip address 198.107.30.17 255.255.255.240
duplex auto
speed auto
interface Serial0/0
ip address 198.107.20.234 255.255.255.252
-->ip nat outside
encapsulation ppp
no ip mroute-cache
no fair-queue
-->ip nat inside
ip classless
--> ip nat inside source list 7 interface serial 0 overload
ip route 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
-->access-list 7 permit 192.168.100.0 0.0.0.255
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password **********
login
end
I took the line:
out since it does not seem to be used for anything.
Check out this link, it has some tools that allow you to test if your public IP addresses are reachable:
http://www.all-nettools.com/tools1.htm
Let me know if you still need help.
Georg
180
