Configuration Help
3825 router with NME-XD-24ES-2S-P EtherSwitch module.
Any one point me to some configuration guides? I wish to use the setup for routing between multiple VLANs and as a VTP server as well (if possible).
Ian
Re: Configuration Help
Ian,
I dont think there is much difference in configuration between this module and modules like NM-16ESW. Check this link for instance.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00800b5d67.html
I guessed as much. But needed to check. I hope to use the SFP port on the Etherswitch module or the router as a VTP trunk port to other 3500,2950 series switches. The Etherswitch as VTP server. looks simple enough.
Ian
108
