Community Member
configuration problem with NAT
Trying to set up a citrix replication site and having problems with access to one site from the other. I do not have access to the second router.
The router I do have access to seems to be the problem. I need to give the replication site access to an public address and can't seem to make it work. I am using static NAT as there are not enough public addresses for a pool.
The server I want to access is dual homed with a public address.
Here is the configuration of my router:
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname rangeramerican-gw
enable password
ip subnet-zero
ip domain-name ALTER.NET
ip name-server 198.6.1.5
interface FastEthernet0/0
description To Office FastEthernet
ip address 10.0.0.1 255.255.255.0
no ip directed-broadcast
ip nat inside
duplex auto
speed auto
interface Serial0/0
description To Worldcom (wcomw0f69726)
bandwidth 1536
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
bandwidth 1536
ip address 65.212.192.xxx 255.255.255.248 secondary
ip address 65.208.9.xxx 255.255.255.252
ip nat outside
frame-relay interface-dlci 500 IETF
ip nat inside source list 1 interface Serial0/0.1 overload
ip nat inside source static 10.0.0.93 65.212.192.xxx
ip nat inside source static 10.0.0.98 65.212.192.xxx
ip nat inside source static 10.0.0.4 65.212.192.xxx
ip nat inside source static 10.0.0.99 65.212.192.xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0.1
no ip http server
access-list 1 deny 10.0.0.4
access-list 1 deny 10.0.0.93
access-list 1 deny 10.0.0.98
access-list 1 deny 10.0.0.99
access-list 1 permit 10.0.0.0 0.0.0.255
snmp-server engineID local xxxxx
snmp-server community xxxx
snmp-server enable traps snmp
xxxx
password xxx
login
transport preferred none
transport input none
line aux 0
password xxxx
login
modem InOut
transport input all
transport output pad v120 telnet rlogin udptn
stopbits 1
flowcontrol hardware
line vty xxxx
password
login
end
thank you in advance for any help.
Re: configuration problem with NAT
Have you ensured that you have proper routing between the two sites ??
Community Member
you use "debug ip nat detail " and let me know the output .
129
