Webcast-Catalyst9k
Configuration reqd...pls. help me...
I want to run/configure Rapid Spanning Tree Protocol (RSTP) on my network topology (pls. see word file as attachment)...
Can anyone help me...
Shahid
Re: Configuration reqd...pls. help me...
Check out this doc...
http://www.cisco.com/warp/public/473/146.html
should find all the info you need in there.
HTH,
Dan
Should be pretty straight forward...
I'll recommend you
- explicitly assign your STP priority ..
- make Core Switch 1 your STP Root...
- make core switch 2 your next root candidate.
you should end up with all ports in FORWARDING state except one of the two ports on Switch 2 that are connected to Switch 1 in BLOCKING state (Alt. Port).
HTH.
Eric
Dear Eric, thanks for the reply.
I am not very much familiar with Cisco commands...reg. RSTP i just know this command only i.e. "spanning-tree mode rapid-pvst"...
Can you write down Switch-wise commands? It will be very help ful for me...
regards,
Shahid
94
