Configuring 3550 for Browsing Management
Hi, I want to know, if it´s possible configure a 3550 so that I can open a
http session with a different level administration than level 15. I configure users in differents levels of administration that works good using
a telnet session but when I make a http session, I don´t have the option to
choose another level than 15.
Thanks.
Alexander.
1 REPLY
Bronze
Re: Configuring 3550 for Browsing Management
You can set up ip http authentication to specify a particular authentication method for users:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tfr/fft105.htm#1020124
The http server command will only use level 15 by default.
95
