Webcast-Catalyst9k
Configuring 3600s for Fast Ethernet to Fast Ethernet routing using wireless
we have meshed network, interconnected using serial lines only. Bandwidth of these serial lines varies from 64-K to 2-MBPS. We are considering Wireless link between major center for link redundancy, since the serial lines are not stable. The wireless links is from Lucent/Wave.
Is there a special attention needs to be given for the FE interface configuration.
1 REPLY
Silver
Re: Configuring 3600s for Fast Ethernet to Fast Ethernet routing
Be sure the FE duplex and speed settings are the same on both ends. You also will need ip route statements with the backup wireless route having an administrative distance of 100 or higher.
91
