Webcast-Catalyst9k
configuring a Cisco 800 with PAT and IP Negotiated
How do I configure a Cisco 803 for PAT and IP Negotiated on the ISDN link to a 3640 host router without running a routing protocol or static routes (on 3640)? The 3640 is configured for IP Negotiate on the Dialer interfaces. The 803 connects on the ISDN/PPP level but because of no static route on the 3640, IP traffic has no route back to the 803.
1 REPLY
Anonymous
N/A
Re: configuring a Cisco 800 with PAT and IP Negotiated
Whoever is configured for a negotiated IP
address should receive an IP address from the
remote end (debug ppp neg to confirm what that
address is). This address should be installed
as a host route; however, if there is
no static route or default route pointing to
the ISDN interface, no traffic will
be forwarded to it. We only know as much
as the routing table, and without a routing
protocol or static routes all that we will
know are directly connected addresses. Use "sh ip
route" when you have problems, this will tell you
how much the router knows at that point.
280
