Community Member
configuring cisco 1603 to connect at regular intervals
hi all..
i wanted to configue the cisco 1603 router installed in our company in such a manner that it connects to the ISP at specific intervals. to be more ellaborate...i want the router to dila to the ISP at 9:00 AM ...then automatically disconnect after half an hour. then again connect after 2 hrs for 15 minutes and disconnect. what i mean is i want to connect for 15 minutes every 2 hrs. is that possible? if yes..then how do i do it.
kindly advise
thanks and regards
Manoj S
Community Member
Re: configuring cisco 1603 to connect at regular intervals
I know I shouldn't do this, but I will assume that this is to allow some kind of service that needs the Internet access to run at specified times (like a mail server dialing out to upload/download mail?)
I'm not aware of a service that will do it natively, but you can set time based access lists that allow traffic only at specified times. Then you could define what is considered interesting traffic, set that to the type of traffic being generated by the mail server, for example, and create a task on the server to dial out at those times specified in your time based access list.
Check the following link on time based ACLs.
