Community Member
Configuring IP for AP 1242AG
I'm new with Cisco hardware, but I have 2 AP 1242AG and I need to change there ip address.
I have tried IPSU and the console option but steel can't change it.
Can someoen please explain the steps to do it?
Paulo Ferreira
1 REPLY
Re: Configuring IP for AP 1242AG
Hi Paulo,
normaly thr IP is set on interface BVI1. I would say try it at the console.
I think you use a user with the correct privelege level. check this if it will not work.
as admin you should use privilege lever 15 ..
conf t
interface bvi1
ip address .......
Or post me the config.
regards,
Sebastian
622
