Configuring NTP on 2900XL
daniel.bowen
Hi there,
I have many 2900XL switches that need to be configured for NTP. We have an NTP server (NTP1) that recieves its time feed from an external clock, but I cannot seem to get the switches to pick up this.
Any help with the config would be great,
Daniel,
5 Replies 5
lgijssel
Level 9
Level 9
The only line that is required is: ntp server
We are using this on a large scale, also with 2900 switches.
Please note that the switch uses the adress of int vlan1 as the source. There might be ACLs active in your network that block traffic from a switch IP adress to a server. First try a ping from the switch. If this succeeds, NTP should work as well.
Goodluck
I have VLAN 1 shutdown, but VLAN2 created instead - will it use VLAN2 instead?
Thanks for your help
Daniel,
Which vlan interface you use is not important. It will work on any vlan interface you specify. Only condition: there must be IP connectivity to the NTP server, that's it.
you can configure the source interface or vlan you want to use by using the
Router(config)#ntp source
Does anybody know any reasons why certain WAN routers would not pick up the NTP source?
I have a UNIX server that acts as the NTP server, then five routers connected to a WAN. The router that is on the same site as the NTP server shows as being synchronised and reference (NTP Server), whereas all the other routers show unsynchronised and no reference.
All are configured the same
Any ideas?
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
