Community Member
Configuring RIP - Network statement
I've got 2 interfaces on 2 devices.
172.18.140.2/24
10.16.15.3/24
I want to enable RIP.
To configure RIP what would the network statement be for the above IPs.
Would it be :
Router Rip
Network 172.18.140.0
Network 10.16.15.0
Thanks for the help.
Green
Re: Configuring RIP - Network statement
It would still appear as 172.18.0.0 and 10.0.0.0 with RIP v.1
You'd need to add "Version 2" to the router RIP section to pass classless information and maintain the 24 bit mask.
The other router should be set for V.2 as well if that's the only routing protocol you're using.
Good Luck
Scott
network 172.18.0.0
network 10.0.0.0
is enough to enable rip on the mentioned networks, because by default its version 1 that RIP runs, which is classful Routing protocol.
give command "version 2" under rip to enable classles RIP.
1068
