Community Member
Configuring Routing on a Spoke/Hub/Mesh Wan
I have configured the primary router,(2620)INDY, with an external ADRAN TSU LT. The second router, (1720)NASH, has an internal CSU/DSU. I have put an IP address on the serial interface and basicaly the routers are connected to each other with a cross over cable for lab testing.
1. I can ping from one router to another only to the IP address of the fastethernet connection. I cannot ping the serial IP's. Is this right or should I be able to ping the serial interface?
2. Even though I can ping on one router to the others fastethernet interface I cannot ping from my laptop to the other router. I am using the following for rouring:
ip route serial0/0.18
ip route serial0/0.23
ip route serial0/0.22
ip route serial0/0.21
Community Member
Re: Configuring Routing on a Spoke/Hub/Mesh Wan
1. You should be able to ping numbered serial interfaces under most conditions.
in a frame relay mapped multipoint scenario, it is sometimes necessary to map your own IP out the dlci in order to ping the local interface.
2. Under normal conditions, I recommend setting next hop to an IP address, not an interface.
Also, your static routes look "wrong" Unless you are using frame encapsulation, I would not expect the routers to use sub-interfaces in a back to back configuration. Without the configurations, I am talking generalities, however.
Hope this helps;
