Configuring Secondary Peers With Crypto Maps
is it possible, when configuring a crypto map to set a secondary peer (under crypto map configuration options), for when your main peer goes down. Or do you have to configure a second crypto map. What is the best configuration option to encrypt my back up link?
Silver
Re: Configuring Secondary Peers With Crypto Maps
Your backup link should have differnet peers than your primary link , if this is the case then you should have no problem configuring this, you will have to create a different crypto map .
You need not configure seperate crypto maps for backup. Just add the command "Set peer x.x.x.x " on the first crypto map config.
This will switch over to the second peer , if the first one is down.
Just try and let us know
501
