Configuring vlan interface on a 16-port etherswitch module?
Can I configure layer 3 VLAN interfaces on a 16-port wtherswitch module for a 3700? You can add vlan´s in the vlan database so theoretically you should be able to do it. I need to know for sure.
Regards, Johan
Re: Configuring vlan interface on a 16-port etherswitch module?
You sure can
Yes you can for sure, it is the based on the cat 2950 switch
Hello, and thanks for the reply...
You say that it is based on the cat 2950 switch.
What I am looking for if it is possible to do internal routing
on that module,
inteface vlan 10
ip address x.x.x.x y.y.y.y
interface vlan 20
and so on.......
Is this possible????
Best Regards, Johan
Yes it is possible. You can do inter-vlan routing
That´s great!!
Do you have any idea of the performance???
Regards, Johan
What do you mean by the performace, what are you planning to do it at this point on that module. Any particular feature etc
116
