Webcast-Catalyst9k
mis
Configuring VWIC for data rather than voice
I need a configuration for my VWIC module so that it will function as a WIC module. I wish to use my VWIC interface to connect to my frame-relay circuit, however, the DS0 can be ordered as needed to accomidate the VWIC. Anyone have any ideas?
Re: Configuring VWIC for data rather than voice
If you looking to create a serial interface use this statement in the vwic 'controller' config 'controller t1(e1) x/x timeslots 1-24 speed 64/56'
YES..you can do that. You can use VWIC for data only. .Here is the url which talks that. Pl. refer to "Features" http://www.cisco.com/warp/public/788/products/vwicmf_t1.html
Now for configuration, pl. visit following url for sample config
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t7/t1_mf_t6.htm#46783
118
