Connect Cisco 1605 to Comcast @home Cable modem
Having some config problems, can not seem to get it to work i have a 1605 Cisco router, and i would like to use it to connect my lan to the cable modem is it posible without extra hardware, if so what hardware would i need.
1 REPLY
Bronze
Re: Connect Cisco 1605 to Comcast @home Cable modem
1605 comes with a 10baseT port. Depend on the IOS, you should be able to configure 'ip address dhcp' on your ethernet interface. Make sure you have the latest IOS that supports this command. I think this command was supported from 12.1(2)T.
Also check: http://www.cisco.com/warp/public/109/router_behind_cm_19268.shtml
105
