07-24-2002 11:46 AM - edited 03-02-2019 12:08 AM
I want to connect two machine that only speaks ethernets. Between this machines there are 2 routes like is shown below:
eth wan eth
machine1 <-----> routerA <-------->routerB <-------> machine2
This machines dont speak IP and the traffic between them mus be unicast.
how can I connect this two machines?
07-24-2002 12:13 PM
Sounds like you need to configure transparent bridging on the routers.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/ibm_c/bcprt1/bctb.htm
07-24-2002 03:28 PM
If you have just those two routers then transparent bridging sounds like the easiest solution.
If you have other routers or other machines that use IP, you can setup an IP Tunnel between the two routers. It takes the packets, in whatever encapsulation, and re-encapsulates in an IP header to the other defined end point which then strips the header and forwards the traffic. Keep in mind this burns CPU on the router.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/inter_c/icdlogin.htm
