Community Member
Connect two switch with gbic ZX --- PROBLEM for the Laboratory TEST
i've this problem. I must try a connection with 2 switch.
A 4500L3 with a 3550.
The fiber from to site A to site B is 90km and the gbic is ZX.
How can i use the 2 switch for the test of the fiber gigaport in laboratory with a fiber of 5 meters?
I haven't a physical attenuator ...... Can i tell a the switch of to limit a power of laser of the gbic ?
Thanks for your help.
FC
Silver
Re: Connect two switch with gbic ZX --- PROBLEM for the Laborato
I do not think there is any other way to test it but use an attenuator. There is no way I know of by means of which you can limit the power the ZX GBIC will transmit signals at.
Community Member
I never heard the power of the GBICs can be adjusted.
I think attenuator is the best way to go...
You can use a very very very long fiber jumper..but you will have to guess the optical loss ( if you don't have a light meter ) and you probably not going to simulate the 90Km of fiber ...
sorry..
Eric
Bronze
You can't adjust the power on the gbic. Your best bet would be a long jumper cable with heavy attenuation.
125
