Connecting 2950 switch to a 3550 switch
Desmond Holoman
I’m trying to connect a 2950 switch to a 3550 switch. I have tried straight through and crossover cat 5e patch cables and the results are the same. There is no indication on the 2950 switch port and there is a slow blinking amber light on the 3550 switch port. The 3550 switch port is on VLAN 1 and the 2950 switch port VLAN 2. Placing the ports on same VLAN does not change the status. When forcing speed to 100 Mbps and duplex to full, there is no indication on the 2950 switch port and the 3550 switch port turned green.
2950 Configuration …
interface FastEthernet0/23
switchport access vlan 1
switchport mode access
3550 Configuration …
switchport mode dynamic desirable
11 Replies 11
glen.grant
on the 3550 try typing in "switchport" on the interface and then switchport mode access . Switch to switch should be a xover cable .
dgahm
Level 8
Level 8
Flashing amber indicates blocked by Spanning Tree Protocol. That would suggest there is another active link between the 2 switches.
If you disconnect the other link the new one should transition to forwarding. There can only be one active link between layer 2 switches.
Please rate helpful posts.
Mohamed Sobair
Level 7
Level 7
flashing amber means there is CRC , errors on ur switch port, Dynamic desirable Makes the interface actively attempt to convert the link to a trunk link. The interface becomes a trunk interface if the neighboring interface is set to trunk, desirable, or auto mode.
I would suggest if u can set ur f0/23 on 2950 switch to dynamic desirable mode & connecting it to f0/23 3550 switch port & let us know the results.
http://www.cisco.com/en/US/customer/products/hw/switches/ps646/products_installation_guide_chapter09186a008049d1f0.html#wp1021241
Off No link, or port was shut down administratively.
Solid green Link present.
Flashing green Activity. Port is transmitting or receiving data.
Alternating green-amber Link fault. Error frames can affect connectivity, and errors such as excessive collisions, CRC errors, and alignment and jabber errors are monitored for a link-fault indication.
Solid amber Port is blocked by Spanning Tree Protocol (STP) and is not forwarding data.
Note After a port is reconfigured, the port LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
Flashing amber Port is blocked by STP and is transmitting or receiving packets.
Hi dgahm,
Yes u are right, the ports led status which written a bove is right, I am sorry it was my fault since I thought it was alternating green - amber. hope we can help out the guy's problem.
I did try this and the results were the 3550 port turned green and the 2950 port remained off. "Down Down" is the state.
Hi Mate,
could u pls enter the show int f0/23 command on the 2950 switch?
pls let us know the output of the show command.
thanks
I typed the wrong port number for the 2950 switch before. Here is the information.
SW2950#sh int fa0/11
FastEthernet0/11 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 0012.01e2.308b (bia 0012.01e2.308b)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input never, output 03:21:20, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 packets input, 64 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
1 packets output, 64 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
trackme
hello,
some things need to be checked here to isolate where exactly the problem is .
1. ensure within the 3550, the switch works ,meaning you can connect systems and works, same applies for the 2950 as well.
2. when you have ensured that, make sure the connection between these two switches are in the same vlan (some time this is required to have both switch ports should be in the same vlan)
3. check the cable if its working properly, u can try that some where else to ensure that the cable is ok.
4.if not working, swap the ports in both switches and try.some times u need to do to eliminate port failures.
5. check the logs or issue a sh cdp n command to see whether that switch is active or not.
i have cascaded several switches and hence it should not be a big deal :)
if still not working, try with another switch say any other unmanaged switch to see whether they can connected to together to eliminate hardware issues as well.
1: When connecting other devices to these switches, the ports function normally.
2: Having the two switches on the same VLAN did not change the status.
3: Cables test good. I’ve had them replace cables with new out of the bag cables. No change :-(
4: Have moves ports. It seems that no matter the port, the results are the same.
5: The switches do not show up in each others CDP table, arp table, or mac-address table.
The ws-C3550-24smi has IOS ver 12.1(19)EA1c
The ws-C2950-12 has IOS ver 12.1(22)EA1
Are there any know bugs with these switches interfacing with each other?
Make sure you use x-over cable to connect them together and also change configurations on your switch ports to as:
2950 Switch port configuration--------------
switchport mode trunk
3550 Switch port Configuration ----------
Shaheen
Please rate the post if it helps !
