Connecting 3508G to Extreme Networks Summit switch
I am trying to connect a stack of GB summit switches to a Cisco 3508G. When I connect the Summit to the 3508, I get a link LED on the Summit, but nothing on the 3508. All the GBICs on the 3508 are known good. Anyone have any experience w/ this sort of thing?
Thanks!
george.burtz@quebecorworld.com
1 REPLY
Re: Connecting 3508G to Extreme Networks Summit switch
George
Few things I would check
1)Make sure the GBICs are of same type
2)Disable auto negotiation on both sides. On the XL you can do a "no negotiation auto"
3)What configuration do you have on the XL for this gig interface and what is the corresponding config on the summit switch(is it a access port or a trunk port)
4)Do a sh intergace gig 0/# and see what the status is
-Prashanth
243
