CONNECTING 3550 WITH WIRELESS DEVICE
I´m have a probelm when I Tried to connecting a Wireless Multipoint Device ROR 1100 form Orinoco to 3550.After few minutes of connection, the line protocol of this port goes down.The port is configured like a L2 with no other issue.Before this switch was arrive, there was installed a DLink switch and the connection works fine.Would you have and idea how can i fixed?
Javier
1 REPLY
Re: CONNECTING 3550 WITH WIRELESS DEVICE
Are you running software that is older than 12.1(14)?
In that case this could be due to sw-issues and I would recommend an upgrade first.
After that, you should check again.
Leo
99
