Connecting 3660 with MC3810
Greetings Cisco Experts,
I have problem connecting my 3660 router with
MC3810 router using the MFT E1 on the MC3810 and
2MFT E1 interface on the 3660.when I do show interface
on the 3360 side it says the serial 5/0:1 Status =>up while protocol =>down
But the interesting part is that when I connect them
using the 2MFT-E1-DI in the DVM module (NM-HDV-2E1-60)on
slot 6 of the 3660 it starts working
I don't know what I'm missing but following is the running config of both routers
3660 Router Config
fax interface-type fax-mail
mta receive maximum-recipients 0
controller E1 5/0
framing NO-CRC4
channel-group 1 timeslots 1-31
controller E1 5/1
controller E1 5/2
controller E1 5/3
controller E1 6/0
framing NO-CRC4
controller E1 6/1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.160.40.26 255.255.252.0
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
no fair-queue
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial5/0:1
no ip address
encapsulation ppp
interface Serial6/0:1
ip address 10.160.63.65 255.255.255.252
encapsulation ppp
router eigrp 1
network 10.0.0.0
no auto-summary
ip classless
ip http server
map-class frame-relay DATA
frame-relay fragment 480
no frame-relay adaptive-shaping
frame-relay cir 1984000
frame-relay mincir 1984000
frame-relay fair-queue
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/1/0
voice-port 3/1/1
voice-port 4/0/0
voice-port 4/0/1
voice-port 4/1/0
voice-port 4/1/1
dial-peer cor custom
MC3810 router Configuration
network-clock base-rate 64k
ip subnet-zero
frame-relay switching
isdn voice-call-failure 0
voice-card 0
controller E1
framing NO-CRC4
interface Ethernet0
no ip address
no ip directed-broadcast
shutdown
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
interface Serial0:1
ip address 10.160.63.66 255.255.255.252
encapsulation ppp
router eigrp 1
network 10.0.0.0
no auto-summary
no ip http server
ip classless
voice-port 1/1
voice-port 1/2
voice-port 1/3
voice-port 1/4
voice-port 1/5
voice-port 1/6
line con 0
exec-timeout 60 0
transport input none
line aux 0
line 2 3
line vty 0 4
Any suggestions will be highly appreciated
aht
1 REPLY
Silver
Re: Connecting 3660 with MC3810
The difference is NM-HDV has the DSP and the necessary support for voice, I dont know what NM module you are using in the failed slot. Also look for the command - ds0-group 0 timeslots 1-24 type e&m-fgb dtmf dnis in the below link
http://www.cisco.com/warp/public/788/voip/voip_cas.html
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_tech_note09186a00800b65d6.shtml
If the module is of NM-1CE1B listed in the below link it will not support voice and if you insert the multiflex card in it, it will not work. You need a NM-HDV module.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_tech_note09186a0080100688.shtml
85
