Webcast-Catalyst9k
Connecting Cisco 3660 (VWIC-2MFT-E1)
Greetings Cisco Experts,
I’m trying to connect two Cisco 3660 back-back using VWIC-2MFT-E1 (RJ 48 cross over)
Cisco 3660(VWIC-2MFT-E1)=====(VWIC-2MFT-E1)Cisco3660
One of the VWIC-2MFT-E1 is in the 2W slot and the other is in the 2FE-2W slot
But for some reasons both of them are not talking to each other and I’m getting
A lot of slip alarms on the controllers
Following is the simple config of both routers
Router 1
controller E1 5/0
shutdown
framing NO-CRC4
clock source free-running
controller E1 5/1
framing NO-CRC4
clock source internal
channel-group 1 timeslots 1-31
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial4/0
no ip address
shutdown
interface Serial4/1
no ip address
shutdown
interface Serial4/2
no ip address
shutdown
interface Serial4/3
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet5/1
no ip address
shutdown
duplex auto
speed auto
interface Serial5/1:1
ip address 10.160.63.22 255.255.255.252
router eigrp 1
network 10.160.63.20 0.0.0.3
auto-summary
no eigrp log-neighbor-changes
E1 5/1 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20000922, FPGA: 15
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
Current port master clock: local osc on this network module
Data in current interval (191 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
191 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
191 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Router 2 Config
controller E1 5/1
framing NO-CRC4
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
clockrate 2015232
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
ip address 10.160.63.21 255.255.255.252
router eigrp 1
auto-summary
E1 5/1 is up.
No alarms detected.
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Current port master clock: recovered from controller 5/1
Data in current interval (868 seconds elapsed):
1 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
Thanks in Advance
aht
1 REPLY
Re: Connecting Cisco 3660 (VWIC-2MFT-E1)
Any suggestions will be higly appreciated
aht
147
