Connecting Offices Clear Channel T1
I just wanted to confirm that this configuration would work:
We are connecting our offices via a point-to-point Clear Channel DS1 that requires B8ZS/ESF framing. I am planning on using two Cisco 2610 Routers with integrated WIC1-DSU-T1 cards. My questions are...
How would I best configure these cards to use clear channel ds1 (no channelization) and to use HDLC as their encapsulation. Also, I need to configure clock speed as there is no clocking on the line.
What would I configure the clock speed for on the DS1 line (1.544Mbps)?
Do I have to configure clock speed on both devices or only one and then set the other to line?
Diagram:
LAN --- Cisco 2610 W/WIC ---- DS1 ---- Cisco 2610 W/WIC --- LAN
Thanks!
1 REPLY
Anonymous
N/A
Re: Connecting Offices Clear Channel T1
The speed should be configured to 1536 kbps. I think you need to set the speed on the bothe sides of the link. You can refer to some configuration guides in thi document:
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl p=Internetworking:T1T3E1E3&viewall=true
104
