Connecting remote location
I have two remote sites 3000 fts a part from each others. We are planning to connect them through fiber cable. Which 2950 Ser. switches I can use those can provide the fiber connection.
I have two WS-C2950C-24 with 100FX connections and want to know if distance limitation will be any issue.
1 REPLY
Bronze
Re: Connecting remote location
As per Cisco docs, the distance limit between the switch port and an attached device is 6562 feet (or 2 kilometers). Check the link below for more info:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12111yj/hig/hgovrev.htm#1065078
HTH.
87
