dal
Connecting two 1751 - same subnet
New install - Two 1751 routers each with a WIC-1T serial card in slot 0. I have router A set as 192.168.0.21 with port unnumbered. I want router B to be on the same subnet - 192.168.0.22 w/port unnumbered also. It gives me a conflict when I attempt to have both on the same subnet. I have done this in the past with the same model router and a DSU card. But for the life of me I can't remember how. I hope some of you more experienced router folks can help me out. Thanks in advance. LDB
Bronze
Re: Connecting two 1751 - same subnet
Are you saying you are putting the same network on both ethernet interfaces and connecting them using IP unnumbered e0? Wont work. You dont put the same IP network in two different places in you network, routing wont know where to send packets destined for that network. If the routers are on the saem network then they have to be connected on those interfaces.
dal
I am saying putting both routers on the same subnet (192.168.0.XXX). And yes, have both routers port unumbered to e0. Each router will have a seperate IP, but on the same subnet. This works great for maintaing small remote sites. I have done this in the past but cannot remember how / or what the command line should read for "IRB" and "BVI". If anyone has any experience with setting up "IRB" and/or "BVI" I would appreciate some advice. Thanks
You need to bridge the traffic on both routers to use same subnet on both sides. Below is a sample IRB / BVI config for doing this. You could also turn off IP routing (no ip routing) and just bridge on the interfaces.
Router 1 cfg;
int e0
no ip address
bridge-group 1
int s0
bridge-group 1
bridge irb
bridge 1 bridge ip
bridge 1 protocol ieee
int bvi1
ip address 192.168.0.1 255.255.255.0
Router 2 cfg;
int e0
no ip address
bridge-group 1
int s0
bridge-group 1
bridge irb
bridge 1 bridge ip
int bvi1
ip address 192.168.0.2 255.255.255.0
dal
Thanks for the info. I will try this today. I will let you know the outcome. Thanks again.
Use /32 subnet mask on both the loopback interfaces.
like 192.168.0.21 255.255.255.255
-Deepu
dal
I guess I will have plead ignorant here, but how will that help? If both interfaces are already on the same subnet. Thanks
Hi, if you don't mind, please send me a copy of the config for both routers to slleong@ntscorp.com
Thanks.
dal
I don't mind at all. It will be delayed a couple of days until the local telcom gets the lines working. This was complicating the problem. I appreciate your help and will forward in a couple of days. Thanks again. LDB
dal
Just got telcom issues resolved. Here is the config. Both routers are the same except for IP. Any help greatly appreciated.
CiscoDalton#show configuration Configure static map list
Using 723 out of 29688 bytesdomain name
!n
version 12.2
service timestamps debug uptime Configu
service timestamps log uptimemcap Modem
service password-encryption
forward
!r
hostname CiscoDalton
multilink
enable secret xxxxx
!n
interface FastEthernet0/0
description connected to EthernetLANst Build a priority lis
ip address 192.168.0.22 255.255.255.0
privilege
speed autod privilege
!a
interface Serial0/0al, m
no ip addressst-routing
version 2
network 192.168.0.0
no auto-summary
ip classless
no ip http server
snmp-server community public RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
password xxxx
login
line aux
line vty
password xxxx
login
no scheduler allocate
end
dal
Here is the correct configuration for both routers - I cut and pasted the wrong one on the previous reply. Ip address the only difference.
Using 876 out of 29688 bytes
version 12.2
hostname CiscoChattanooga
enable password 7 1404071B1C0B383F75
memory-size iomem 25
ip subnet-zero
no ip domain lookup
bridge irb
description connected to EthernetLAN_1
no ip address
no keepalive
speed auto
bridge-group 1
interface Serial0/0
description connected to CiscoDalton
ip unnumbered FastEthernet0/0
bridge-group 1
interface BVI1
ip address 192.168.0.21 255.255.255.0
router rip
version 2
network 192.168.0.0
no auto-summary
ip classless
no ip http server
line con 0
exec-timeout 0 0
password 7 111A0C15071D1918
login
line aux 0
line vty 0 4
password 7 095F5B19090A0506
login
end
150
