connecting two branches having the same Network ID
I have 2 branches offices, both are using Newtork ID 192.168.100.0. They r going to be connected with Cisco 1721 series router at each branch using leased lines. Can I configure the routers to act as bridges, or there is any way to do this design.
Green
Re: connecting two branches having the same Network ID
Until you change either or both address blocks, you can use NAT on each router. You'll need to do static mapping to hit a specific resource at the remote end ... kind of a pain, but it'll work.
Host (192.168.100.1) -> router/NAT (10.10.10.1)-->WAN-->router/NAT(10.10.10.2)-->server(192.168.100.1)
In the example, you'd need a static NAT mapping on 10.10.10.2 that sends the traffic to (specifically) server(192.168.100.1)
If you set up the routers to bridge, then the host addresses at each end will need to be unique (you can't have a ".1" on both networks).
Good Luck
Scott
Hi scott,
Thanks for your reply, consider that I have unique IPs on both networks, Can you tell me how to configure a router as a bridge, get me a link if possible.
best regards.
213
