Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Connecting VLANs with NonCisco Switches
Here is the issue: I have a 4506 running 5 vlans to segment my network, however we have run out of ports on the 4506 and need to add some addtional switches. Manangement wants to use the the leftover non cisco switches we have laying around. How do I add these switches to a single vlan without causing any issues. Of course these switches do not speak ISL.
-K
1 REPLY
Re: Connecting VLANs with NonCisco Switches
Just configure the 4506 Ethernet ports as access-mode ports and put them in the relevent VLAN. Then just ensure the non-cisco switches are default (i.e. all ports are in VLAN 1) and then connect them to the 4506 on the access ports you have configured.
I am assuming you are only using one connection per switch and you aren't going to create any loops etc?
Andy
86
